Auidiophile/Basshead upgrades.
Kania2k1
Okay, I'm abit of an Sound Q freak now, and also a reformed basshead.  Meaning that I like to have my music sound like it's being played in front of me, but I also like to blow the windows out of the passing cars sometimes.  i'm planning on upradeing the stereo in the rig, but I'm not sure how to do the subs and amps.
 All my installs have been in sedans so I've had a trunk to work with.  With the truck, I lose that option, obviously!  So my issue is similar to Claw's.  I want to keep the rear seat, but I really don't hauld anything that can't stay in the bed or under the tonneau.  What I was considering is putting in 4 10" JL's (probably w-4's, but that could change).  Planning on running 2 Fosgate Power 500.1's to the subs, and another 4 channel to the highs and mids.  My main question is how much room is there behind the seats.  The amps are going to have to go there, because I don't want to cut throught the bed, being in the salt belt, and the EQT's are going in the bottom of the rear seat.  I was planning on building a bracket for each side to move the top of the seat forward a little so I could get a little more airflow.  Any ideas?  Thanks alot, sorry to ramble!
a friend of mine has a 98 z71 and put to amps moounted behind the back seat against the wall, then added 2 tubular fans that were on either side of the amps to make sure the were kept cool, looks really good and he has had no problems with that setup. had the install professionally done and look nice
Looks Nice Smitty!!  I was considering doing something to that effect also. Considered just building an amp rack out of Aluminum or something like that.  I'll have to listen to the truck with 2 subs before moving on to 4 though.
I was planning on istalling at least 2 fans behind the seats.  If I can figure out how to get fresh air into the fans it would be even cooler!
I'm going to probably just go with a single 10" in one of those sealed boxes that goes under the rear seat.  I don't really want it to shake the neighbor's windows when I come down the street, we already have a doofus who has 4 12" subs in the back of his Jeep Cherokee.  I just want it to have decent, clean, tight (above all) bass.
I'll probably change the back speakers then, but they aren't bugging the hell out of since the bass blockers are killing the low end, like they did before.  I was figuring on buying a 4 channel amp, run 2 ch. bridged on the sub, and run the backs off the H/U, and the fronts, with the bass rolled off under 150hz or so.  Should sound good!
i got a 5channel amp mounted behind the seat, no heating problems at all even when running full out,  but with 4 subs and 2 amps you might be pushing it.
    DaleB
    DaleB
  • Who's Online   7 Members, 0 Anonymous, 1,301 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
