Possible Head Gasket Failure
boyhonda5
2003 GMC Sierra 2500HD with 6.0 gas V8. MIL on with p0300 stored (random misfire) #5 cylinder misfiring severely. swapped injectors, coils, plugs and plug leads from good cylinders, no change in misfire location. cylinder compression is much lower than others (140-150 psi) while others are 170-185 psi. cylinder also has excessive leakdown (31%) has been run hot while towing, and has signs of external coolant leak, but not constant leak.
The compression doesn't sound low enough to indicate head gasket to me. I would be thinking more like valve not seating correctly especially with the leak down #s. Either way you are pulling the head on this one assuming the leak down test was done correctly.
You can check for a cracked head/head gasket with a combustion leak detector like THIS ONE.
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 268 Guests (See full list)
