Wiper Fluid Reservior
I did a vague search but didnt go through the 34 pages that came up. I didnt see what i was looking for.
This is my 3rd GM truck that has had problems with the reservior. My 99 Z-71 and 02 Tahoe had the problem with the reservior not holding fluid. I recently purchased a 02 1500 HD GMC. After i had it a few days i needed to wash the windshield (friggin birds) and nothing came out so i assumed this truck had the same problem as the others. I go to look at it yesterday and the reservior isnt even there so the previous owner must have just took the thing out since it was useless.
Question is: Why do so many of these things leak and where would you guys reccomend buying another one? I know there are several sites that sell parts but i've never ordered online for a GM (i've been driving Fords for a while :smash: ) and would like opinions on a good place with great service to order one.
Thanks,
Keith
1. Go to a junkyard and get one from a truck.
2. Take it home and fill it with water.
3. Hang it somewhere and wait.
-3b. Crack open a cold one.
4. Keep an eye on it for leaks.
5. Find leak and smear some epoxy or something over it.
-Step 5 isn't necessary if there is no leak.
6. Install in your truck.
7. Wash the windshield at your convenience.
That 'oughta do it.
That 'oughta do it.
:lol::smash:
I havent had this problem personally! A buddy of mine does have this problem though. It's kinda hard to say if it was doing it from the beginning as the front end of his truck was taken out a week after he got it. It has not held fluid since the day he got it back from the body shop, that was about 2 yrs ago. He has a 2007 NBS. Hopeully you get it situated!
That 'oughta do it.
Sounds like a good plan to me.
Thanks,
Keith
I repaired one on a friends 02 Tahoe several years back....leaking battery caused the pump on the reservoir to corrode thus causing the leak. Replaced the pump and everything was good again.
    250.3k
    chfkief
    chfkief
  • Who's Online   1 Member, 0 Anonymous, 1,482 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
