Trimming the factory antenna
My trucks antenna is about an inch too tall for the garage door, can the anteanna be trimmed or will these muss things up w/ reception?
Any other alternatives aside from a billet antenna?
Seeing as you have to do something, go ahead and cut it.  If it works, great.  If it doesn't, all you are out is a stock antenna and you can get one that is sized correctly.
You have a number of choices:
1. Let it slap the lintel until it wears a slot that you can aim for.
2. Let air out of the tires - remember the little kid and the bridge story.
3. Unscrew it each time you put the truck in the garage.
4. Clip it - with or without benefit of clergy - this will mean that you can only recieve the lowere numbered stations.
5. Charge for sigs to get cash for a Billet.
Hope this helps :D
Jon, I was at Advnce Auto Parts today and seen a replacement , GM compatible, antenna.  It looked pretty much like the stock one, but it was about 4-5 inches shorter.  I think it was under $10.00.
Gandolph, thanks for the suggestions, that'll be fuve bucks for your sig :D
Tom, I'll check w/ advance auto and see what I can find, sounds like a good idea.  Also, I've got Joe checking his on his blazer to see if it's shorter, may just get one of those if it'll work.
I would just look for a replacement one, and not hack the old one off, but if you do, you can't hurt anything, except it's looks.  I see a Tahoe with a shiny short aftermarket antenna once in a while, and it looks good.
    Sothpaw27
    Sothpaw27
  • Who's Online   6 Members, 0 Anonymous, 573 Guests (See full list)
