New HU or will a new amp work???
I have a 2002 Chevy 2500HD Crew Cab w/OEM stereo
Can I just add a 4 channel amp or would I be better off with a new HU w/25 watts per channel? The only reason I consider an amp instead of HU is for security reasons.... a new HU draws attention.  I'll eventually replace the stock speakers and am working on sub possibilities now.
What are the pros and cons?
Thanks!
Hutch
I am going to add amps and 2 10" subs to my factory head unit.
I like the factory appearance, the Sound level volume control, and the sub option with the amp + line level converter ($8).
If you like your factory look, then keep it, but i absolutely hate the way they incorporate amps into your existing speaker wires.
I chose new HU w/removable faceplate (course i got an alarm also), new speakers, and new amp for the fronts.
But hey, if someone wants to steal your stuff, theyre gonna do it anyway.
Dihappy,
Can you explain what you mean when you say, "...but i absolutely hate the way they incorporate amps into your existing speaker wires"?
I agree totally, if someone wants your stuff, they will get it somehow.
What HU and amp did you get?
Thanks,
Hutch
What i mean is that the factory units do not have pre outs and therefore any amp has to be connected thru speakers wires (im not an auto tech guy) somehow.
I purchased a Pioneer 8400 MP3/XM capable deck.
Kappas speakers all the way around, and a Kicker 60x2 amp for the fronts (till i can get a 4 way).
Still need another amp and subwoofer.
XM is really nice, and the HU and XM stations are great!.
The 8400 has 3 preouts:
Front
Rear
Sub
So its very expandable.
you really should do both. if you just amp the signal from the stock head unit its going to be all unclear and distorted. and if you try and run speakers off deck power (they say 25watts, but its more like 10) you'll get the same problem. but if cost is a problem. head unit first.
  • 5 months later...
I would start with the amp and speakers.  Many times, even with cheap stock stereos, it will increase the performance enough for the average person, and if you still aren't happy, you can go back and put in a new head.
  • 1 month later...
I would start off with a Amp and a sub. The factory system is not that bad if your keeping the factory head. Adding a sub will add low end and take the load off the factorys right where they lack the most. You will need a Speaker level to Rca converter to hook RCA up to the factory head. They cost about 10 or 15 bucks. I used them on a sub install before but never on a speaker install.  If you add a amp to your factory speakers you will not notice any improvement soundwise, you will prob just blow your speakers out.
If you only have the money for one, get an amp.  A head units internal amp cannot compete with a real amp.  The ratings on head unit power are peak ratings, meaning that is the most it will put out.  They actually put out about 10 watts RMS (RMS is not exactly average, but for our purposes we can call it that), and the quality is pretty poor.  Most reputable amp manufacturers will rate their amps in RMS not peak.  Although in reality, RMS wattage doesn't really exist   ???   but we wont get into that.
    • Check the windshield washer reservoir bolt. They ALL are loose from the factory.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
