Tweeter400 Posted June 14, 2002 Posted June 14, 2002 I have been doing some studying and have a question. Which is a better way to filter the freq. to components, with an amp or crossover??
Kania2k1 Posted June 16, 2002 Posted June 16, 2002 If you are going to use a crossover, get one that you can use for teh entire system. The amp ones are fairly limited to which frequecies go through. Something from Audio Control for example, will run the entire system. I'm not sure if yu would need one for ech channel though. There are several companies that make decent crossovers. I'd check some of the web sites. The Car Audio and Electronics yearly directory has all of the manufactuer's web site's listed.
badpewterz Posted June 16, 2002 Posted June 16, 2002 a crossover definetly most component sets come with the cross over if you use just the amp you'll cook the tweeters real quick, they dont like low and mid range signals the only crossover on an amp that i use is for my sub switched to low pass
