After Market Remote Starter
Bruins04
I have an 04 Sierra base model.
I'm looking to put a remote starter in it.
Do I need a by-pass part to trick the truck to thinking a key is in it?
does it have power windows and locks?
Power Locks.
I called a dealership & they said with a base model & that year it does not have a chip.
.. does that mean there is no PassLock chip at all... or does it mean the key cylinder has the old PassLock system...??
there is still a passlock system in all gm vehicles, you must get a bypass kit to bypass the passlock system, what the bypass kit does it temporarily bypass the oem passlock system allowing the vehicle to start via remote. i just put one in my 06 gmc sierra base model truck that has windows and locks. the difference between what kind of bypass kit you want to get depends on the options you want and if your going to be unlocking and locking the doors with the new aftermarket system or not, you will not need to leave a key in the ignition, i went with XK01 bypass kit from DEI, the best prices i could find were on ebay for 25 shipped, the best part about the xk01 is that its upgradeable if you want more options in the future and theres alot less splicing of wires to the truck because everything runs through the data line in pin 2 (violet wire) of the OBDII connector under the drivers side dash board.
So how does the bypass & remote started connect to each other?
basically yes the remote start controller wires splice to the wires from the bypass module, power and ground can be shared, purple wire from the bypass splices into pin 2 of OBDII connector under driver side dash, no need to even connect siren or light outputs from the aftermarket remote start controller because with the xk01 bypass it will control the lights and horn like an oem gm keyless would which is why the bypass kit saves you time on installation. if you go to that link i posted you can look up the wiring diagram for xk01 bypass to aftermarket remote start/alarm. i think your going to want to look under the amdl firmware if i remember correctly.
This does not state that it is for remote starter bypass?
Windows & Locks.
http://cgi.ebay.ca/XPRESSKIT-XK01-PROGRAMM...#ht_2006wt_1167
XK01 - AMDL 6.00 (2004 GMC Sierra)
  • W2W
    AV-Horn Chirp activation
    CC-Defrost Activation
    CC-Heated Mirrors
    CC-Heated Seats Activation
    CC-Power Mirror memory
    CC-Power Seat Memory
    CC-Power Windows Rollup
    CC-Radio Channel Memory
    DL-Arm Factory Security
    DL-Disarm Factory Security
    DL-Door Lock Control
    DL-Door Unlock
    DL-Driver Priority Unlock
    DL-Sliding Door Control Driver
    DL-Sliding Door Control Passenger
    DL-Trunk / Hatch Release
    PK-Immobilizer Bypass-Data No Key Req'd
    RS-RAP Shut Down (Remote ACC Power)
    SS-Entry Monitoring ALL Door Pins
    SS-Entry Monitoring Front Door Pins
    SS-Entry Monitoring Trunk/Hatch Pin
    ST-Door Locks Status
  • D2D
    AV-Horn Chirp Activation
    CC-Defrost Rear Window
    CC-Heated Mirrors
    CC-Heated Seats
    CC-Power Mirror Memory
    DL-Door Unlock
    FOB- CAN alarm control w/FOB remote
    RS-Intake Air Temperature
    RS-Tach / RPM Output
    SS-Entry Monitoring Driver Door Pin
    SS-Entry Monitoring Hood Pin
    ST-Ignition Status
Features:
Xpresskit includes Free and unlimited access to updates and new firmware solutions as new vehicle platforms are released. Xpresskits are user programmable and upgradeable, making obsolete and excess inventory a thing of the past, plus you don’t have the expense of stocking as many parts.
Every XPRESSKIT is shipped preloaded with default firmware that provides the most comprehensive combination of valued features, functions and vehicle coverage. For this reason even if you do not have a computer you can still benefit from the best technology has to offer, right out of the box.
Tomorrows’ technology is just a click away, however still the most valuable reason for choosing XPRESSKIT are the PRELOADED features that provide right out of the box functionality. Local manufacturing allows each XPRESSKIT to be flashed with the absolute latest firmware just prior to shipping ensuring that you have compatibility with the latest vehicle releases.
XPRESSKIT interfaces the past, present and future whether you have a computer or not.
  • Preloaded with the latest firmware covering the most popular vehicles.
  • Pack full of the primary features and functions you need most.
  • Built in D2D port (data to data) for easy upgrades and programming.
  • Dual purpose D2D communication port also connects with D2D enabled remote start systems.
  • Upgradeable via PC / Internet / Handheld.
  • Enhanced security when using D2D secure single wire data override.
  • Wire to Wire compatible with any brand remote start & security system (W2W).
  • Compatible with manufacturer's Factory On Board anti-theft & content theft security system.
  • Secure data transfer maintains integrity of factory anti-theft & alarm system.
  • Compact, durable design is easy to mount and built for extreme weather.
  • NKR - No Key Required for operation means vehicle owner does not have to give up a key.
  • Simple, straight forward instructions and programming means time saving installs.
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 453 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
