Replace stock sub in 02 Tahoe?
Anybody swap out the stock subwoofer in their Tahoe or Yukon with an aftermarket one?  Does it bolt right in?  How does it sound?  I want to do this, but want recommendations.
Hey, i replaced my stock sub with a 8" JL AUDIO W3-D2.  IT ROCKS THE TRUCK.  I powered it with an mtx 300 watt amp.  (also replaced speakers w/ Boston Acoustics).  DEFIATELY WORTH IT.  Fit right into the factory location.  You will need a hefty amount of sound dampening material inside that factory location.  It may sound like it woud be a weak sound because its only 1 8, but it truly isnt.  IT CAN REALLY HIT (even though aint QUITE as much as if i had 2 12s :D).  If you want a 10, but still keep the stock look, you can get a stealth box because they have a 10w3 in it.  I heard its good, but dont have one, so i'm only going on word of mouth.
Ben
Do our 9-speaker Tahoe's have an amplifier already?  When you put in an aftermarket amp, do you replace what's there, or is it just an add?
Thanks,
Barry
good question.  To be quite honest, i have no clue.  I didnt do the install.  But you WILL want to add an amp no matter what.  If you dont have an aftermarket amp you will put too much stress on the new system, and it will blow out.
Ben
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
