Putting Fuel In Gmc Trucks
eldragster
I bought a 1989 GMC Dually and you have to put the fuel nozzle in upside down and put fuel in really slow to keep it from splashing out. My dad has a 1987 GMC that has the same issue. What is going on?
The place I work at has Ford ton truck with a flatbed on it that is the same way.We carry a little block of wood and drive the duals up on it and it takes gas at full speed from the pump.Has something to do with the fuel neck and the flatbed setup.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
