Leveling A Truck With New Front Shocks
Is it possible to level a stock 2004 gmc sierra z71 by just replacing the front shocks? Or is there other parts that have to be replaced if I bought a taller shock?
you could just adjust your torsion bars by tightening the bolts below the torsion keys, i leveled my truck that way, it rides alot tighter now, not uncomfortable just not as much play going over bumps, i got a lil over 2 inches in lift that way and i didnt adjust them all the way up because iv heard people say not to and i just wanted to level my truck anyways, the bolts werent even touching the torsion keys before i adjusted them.
The shocks have nothing to do with ride height. The springs hold the vehicle up.
There are torsion bar keys that you can use to adjust your ride height with (or "level" your truck). Measure your fender heights, jack up your truck, turn the torsion key bolts all the way in, put truck back down and measure fender heights again. Repeat procedure but back out the torsion bar bolts individually until both sides of the truck are level. You should end up with between 1-1.5" of increased ride height in the front using this method.... then just go get an alignment and you're done. (stock torsion keys for your truck usually don't allow beyond 1.5" of height, and for good reason)
Edit: Scott, you were able to get 2" from your stock keys?
What do the leveling Bilsteins do differently?
technically, they do the same thing.
your truck doesnt have torsion bars & keys, you have a coil spring and coil body (incorrectly referred to as a strut).
for torsion bars, twisting the keys adds preload so less deflection is required to stabilize the trucks weight thereby increasing ride height.
for coil springs the new coil bodies do the same thing, they add preload (by compressing the spring) so that when the weight of the truck is applied less deflection is required to stabilize the truck (because the initial deflection is performed by the coil body setting rather than the vehicle weight)
So would you go with the RC kit and mill it down to 1.5" for their special price of $29.95, or stick with leveling the bilstein's if that is how much I planned on spending to begin with?
either would work just fine. i personally would go the RC kit route for the price.
Done deal then. If for some reason I change my mind I am sure I can sell them and not lose anything. I have a mill at work and know how to use it, so I plan on taking them down to 1.5".
I have an 04 Z-71 that I want to level. If I use the aftermarkets keys (or Ford keys) that lift the truck 2 inches instead of tightening the stock ones will it keep the stock ride?
I would just take it to a shop or do it yourself and have your torsion bars cranked up slightly on the truck. Two bolts underneath the cab part of the truck. I had new tires put on two weeks ago and the shop cranked mine some while it was there. Looks so much better. I mean i liked my truck before but on a RCSB, it took that front rake out for the most part, and still rides the same as before. Just don't go overboard and go above 2 inches. 1.5 is about right. Ryan
Thanks! I might turn them up and try that. I know I should get an alignment when I'm finished. but will I need longer shocks?
you wont need longer shocks, especially since you have the oem upgraded bilsteins.
if you want new shocks, get a quality oem replacement... not ones for a lift, they need to be able to compress just as far as stock ones.
Thanks!! I'm gonna go for it. I have to wait 'til I get the money for an alignment. I'll post some pics.
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
