Duel Batteries
tims0209
How too. I added a second battery the same way I've done on older models with a marine battery switch. Not working. :rolleyes:
My truck goes without use for a week or two at a time. My after market alarm with GPS draws power while parked. When the truck is in use we often tailgate awith the stereo on.
The set-up has shorted out 2 batteries.
I like simplicity, not trying to be cheep.
Thanks, Tim
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 266 Guests (See full list)
