Denali Electrical Gremlins
Today the temp dipped to around 11 degrees outside and I also had a first time electrical issue. Not sure if they are related but here goes...
When I shut the truck off, there is no reserve power and the clock resets to 12:00 and you hear the CD changer going through the cycle.
When you re-start the truck, the auto setting for the HVAC is off and the rear aux AND the dual climate controls are lit up.
I have looked at the manual and can't figure out which fuse to look at to make sure I don't have a bad fuse. I reset the clock and it happened a few times tonight running errands
Then after sitting in my garage, I reset the clock and leave it for a few minutes and no issue.
I go out for a test drive and boom, it does it again... this time when I click on heated windshield washers everything on the dash blinks on and off and while driving. I think I am screwed because my dashlights are flashing all over the place and then I go on like nothing happened.
After playing the internet, I find this so I pulled the fuse to see if that does anything before I can find if my truck had the update by the PO (I bought it used 2008 with 12K miles). No stickers under the hood which are usually added by the dealer after the recall is fixed.
Here is an excerpt of what I found - what do you think?:
Unfortunately, these features occasionally do the exact opposite as electrical gremlins take control and make them malfunction. Such is the case with a 857,735 vehicles from General Motors built between 2006 and 2008 that are equipped with heated windshield washer fluid. Apparently, the system is liable to short out, causing it to stop working and even smoke, give off an odor, and make other on-board electronic systems go haywire. To remedy the problem, dealers will add a new wiring harness with an in-line fuse, which will short out before the problematic printed electrical circuit does the same.
Vince
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
