Still Confused About Wheels
I was looking at the Pro Comp Xtreme Alloy 6001
The truck is a 2009 Z71, The tire size is 285/75R-17
Rough Country 3" Suspension Kit, Tires do not rub with stock wheels, will they rub with the aftermarket, the specs on the wheel are.
17x9, 6 on 5.5 Bolt Pattern
Backspace = 4.75 in.
Max Load = 2200lbs
Finish = Chrome
Hub Centric = No
Offset = -6mm
You really need those wheels to be +18 to +30mm offset (5.5 to 6.0" backspace).
With 4.75" backspace you may have rubbing issues. Not to mention the tires will stick out more than an inch beyond your fenders (unless thats the look you're going for...)
To put it in perspective, your tires will stick out 1" FURTHER than mine:
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
