4l70e Failures
Has anybody had any problems with their 4L70E? My 4L70 lost second gear, taking it to the dealer to get the transmission fixed. When my warranty runs out, I'm thinking about ordering up a Level 5 4L70e from FLT. All the manual gears work good, and reverse and park work normal. Warranty will cover my transmission, but when warranty goes I'm saving up to get a built 4L70e. So, how is everybody else 4L70?
No issues with mine (25,000 miles) I've never had any issues with any of my 700R4/4L60-E trannys.
How many miles on yours?
39,000 on mine and not a lick of trouble so far.
I also had Justin remove 100% of TM in regular mode. In addition I tow on a regular basis too. But, Justin left all of the TM in T/H mode.
My transmission has 70,000 miles on it, it was working perfectly until the other day. I like how Chevy stands behind their product and I am getting my transmission fixed at the dealership already.
70,000.....That thing don't sit still does it?! :cool:
I use it for work and going out so the miles go up quick.
38,800 miles and no issues... and I tow too. :cool: Glad to hear the dealership is fixing you up.
Yeah, very happy with the way the Chevrolet dealership is helping me fix my truck. Never had a big warranty claim like this one, on my other trucks it was always smaller things than this. Very satisfied with the way GM stands behind their products.
So they are fixing your transmission even though you have a Black Bear Performance Tune??? Interesting, I'm assuming you've swapped out pcms or they aren't too bright and haven't compared calibration numbers with the Tech II. Way to go with getting away with that one :cool:
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
