Gibson Supertruck Exhaust Tips
For Sale: One matched pair of Gibson stainless steel exhaust tips; 2" inlet, 2 3/4"x6" outlet, clamp-on. New, only taken out of the box for photos. $80.00, including delivery. PM me if interested.100_0112.jpg100_0114.jpg
PRICE REDUCED! $70.00 per pair, delivery included.
This is my New Year clearance price. Get 'em if you want 'em.
PM if interested. Thanks.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
