Regular Cab Long Bed
Im curious to see what all your regular cab long bed 2500HDs look like. Im thinking about putting nerf bars on my truck but would like to see a picture of someone elses. Also looking for pics of reg cabs with a leveling kit and 285/75s. Thanks!!
Probably not the body style you are looking for but here ya go! BTW, I've got 295/70R17's.
Is it possible, or should I say, good for your front end, if I installed a leveling kit on my 04 2500HD plow truck?
Pros and cons? I like the look of the factory height just would like to get rid of the front end sag.
Well thanks!
Yes, nice truck hockeypro. Is that a 6 inch lift on there?
Yep. 6" FullTraction kit.
I'm not sure about the general consensus of leveling kits and plowing, but most guys who plow with these trucks just crank the torsion bars a few turns and add Timbrens to the front end to carry the weight of the plow when it's on.
ReadyLift torsion bar keys...with the amount I did, I probably could have just cranked the stockers...
And nothing in the rear? That looks like a nice stance. That's it, I'm giving mine a few cranks today.
Correct, nothing in the rear.
