Newbie Question?
Hi, Guys.
I have searched the forum, but I can't find anything on this. This is my first GMC, and I have never noticed it on previous trucks. On the rear cornerpanel in front of the tirewell (on the body) there is a clear piece of plastic or tape...what the hell is it? There is a smaller piece on the other side towards the bumber end. Can I peel this off? Is it supposed to stay there?back
Cool! That's all I needed to know. Thanks!
I agree, keep them on. I took mine off because my truck is white and after a while the edges of the protective film started to get black and dirty, so you could see the outline of the film. On a dark truck like yours, you probably won't even notice.
If you decide to take them off, they come off easily.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
