1997 Sierra 100k Tune Up
I'm looking to give my truck a tune up, as it has 100,200 miles on it as of today Things I've thought of so far:
Transmission fluid and filter change (just dropping the pan, no flush)
New Fuel Filter (which has already been ordered and I'll probably put it in the next couple of days)
New Shocks (I think the ones I have are originals)
New brake pads
These have been done in the past 2,000 miles or less:
New Iridium Spark Plugs
Oil Change (synthetic) and new Oil filter
New front tires
Any other suggestions for those that are familiar with GMT-400 trucks? I plan on keeping this truck for as long as possible, since I prefer the GMT-400 style over any other style truck, even the newer trucks oddly enough, and hope to have it run at its best.
New brake pads
New front tires
Cant tell if you have a 4X4....so if you do...change the T-case fluid and both diffs...if its a 2wd...change the oil in that diff.
I would flush and fill the brake fluid too...and Power steering.
Oh and check the pH and concentration/freezing point of the coolant.
... might also be a good idea to have a good injector flush ... Vortec injectors can be a problem when deposits start to build up on the poppet valves
... at the 100,000 mile mark you should check the condition of the distributor cap and plug wires as well ... these ACDelco plugs and parts are usually good for over 100,000 miles
... and then with freshly clean injectors and good ignition parts ... when the truck begins to get hard to start, you can focus on the fuel pump, knowing the other stuff is all good!
Check your front end really good. Here in Michigan we have bad roads and it does a number on ball joints, tie rods, etc. I have also seen plug wires, caps, and ignition rotors fail at less than the mileage you have especially in humid conditions.
This is what I would do...
One can of seafoam in fuel tank,
change oil & filter, gas filter, air filter, pvc, check belts, all fluid levels and just enjoy the ride.
Most importantly watch your coolant level as these trucks seem to have a problem with the intake manifold gaskets leaking so you start losing coolant.
After a few tanks of fuel add another can of seafoam to fuel tank and fuel system should be clean and good to go.
I'm old school, if it ain't broken don't fix it. just stay up on your proper maintenance.
Spend your maintenance money wisely: big cost item is trans and differential, change oil in them if you do not know when they were last serviced.
Sounds like you got it covered pretty good.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
