Automatic Rainsensing Wipers
I have no idea how to turn this function on. Does my truck have this?
I know GM deleted that option on the 2010 Escalades, maybe the '09 Denalis too?
Edit: Just googled it. Your truck should have the option.
To turn it on, make sure the arrow is pointing on the lower 3 levels. The top two will over-ride the system, but the bottom three are for the rain sensing system. The highest one is the most sensitive (one I use all the time), and the lowest one is not as much sensitive. Sometimes when it rains, the wipers won't work unless you toggle it back and forth.
Made this n00b picture. Should help you. :confused:
From pg 3-11 of my 09 sierra owners manual:
Rainsense™ II Wipers
For vehicles with Rainsense™ II windshield wipers, the
moisture sensor is located next to the inside rearview
mirror and is mounted on the windshield. When active,
these sensors are able to detect moisture on the
windshield and automatically turn on the wipers.
To turn on the Rainsense feature, the wipers must be
set to one of the five delay settings on the multifunction
lever. Each of the five settings adjusts the sensitivity
of the sensor.
Since different drivers have different setting preferences,
it is recommended that the mid-range setting (position 3)
be used initially. For more wipes, select the higher
settings; for fewer wipes, select the lower settings located
closer to the off position on the multifunction lever.
The sensor will automatically control the frequency of the
wipes from the off setting to the high speed setting
according to the weather conditions. The wipers can be
left in a rainsense mode even when it is not raining.
When Rainsense is active, the headlamps will turn on
automatically if the exterior lamp control is in the
AUTO position and the wipers are active.
Notice: Going through an automatic car wash with
the wipers on can damage them. Turn the wipers
off when going through an automatic car wash.
  • 6 months later...
of the sensor.
OK so I just bought a 2010 Denali which I "assumed" came with the rain sense, since there is no sign of it on the vehicle can this be retrofitted? :dunno:
I dont need something to tell me when to turn my wipers on haha! Like its so damn hard to turn them on yourself! I never heard of such a thing! Thats to funny
OK so I just bought a 2010 Denali which I "assumed" came with the rain sense, since there is no sign of it on the vehicle can this be retrofitted? :fume:
I just bought a 2010 denali as well. Found out GM deleted that option. I have it on my 2008 Escalade and use it.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,003 Guests (See full list)
