Drivers Side Drop
Question, 2008 1500 Crew cab Vortec Max, the truck has had a driver's side drop. The front left of the truck sits a half inch lower then the Right Front. The left rear sits One inch lower then the Right rear. It doesn’t matter if the truck has a full tank or not. I have empted the truck and measured it on flat ground several times. I just recently added a front spacer and rear block leveling kit. The truck was aligned after. No issues in the alignment. The truck goes straight down the road no pulls or anything.
Any ideas let me know thanks
Question, 2008 1500 Crew cab Vortec Max, the truck has had a driver's side drop. The front left of the truck sits a half inch lower then the Right Front. The left rear sits One inch lower then the Right rear. It doesn't matter if the truck has a full tank or not. I have empted the truck and measured it on flat ground several times. I just recently added a front spacer and rear block leveling kit. The truck was aligned after. No issues in the alignment. The truck goes straight down the road no pulls or anything.
It's called the Chevy lean......
The Chevy lean? hmmmm, i have seen many of these trucks and I haven’t seen one that is that noticeable
Mine does that too. I thought it was just from hauling my fat a** around for 98,000 miles.
I will call the dealer tomorrow about it. I guess its just more that I stare at it, that it bothers me.
    Camyon
    Camyon
  • Who's Online   5 Members, 1 Anonymous, 1,183 Guests (See full list)
