Power Extending Mirrors
I have a set of power extending mirrors that I took off my 2005 Silverado LT. The driver side mirror will shake slightly at highway speeds, but only at certain angles. Overall, they are in great condition, and I only switched them because I like the power folding option. They also are auto-dimming and they have the turn signal in the mirrors. I paid around $200 a piece for my power folding ones, and I'm asking $250 for the pair O.B.O.
I will post a few pics, but I have more if anyone is interested.
Thanks,
Randy
Thanks,
Randy
Here are a couple more pics:
  • 4 months later...
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
