Weird High Beam Problem
I have an 08 Sierra Denali. About six months ago, I converted all my lights to HID. I am using the supplied wiring harnesses for the three sets of lights. Up until a week ago, they worked fine. The other day I noticed that my high beams would not turn on. Note: this is with the headlights in “Auto”. I always use auto.
I figured that the relay or fuse was blown and just checked them. They are fine.
Here’s where it gets weird. If I put the headlight switch in manual, I can activate my high beams. When in Auto, they will not come on and the high beam dash indicator does not illuminate either. If I pull the high beam / turn signal level back to flash the high beams, they will come on regardless if the switch is in auto or manual.
I have checked all headlamp fuses and they are good.
Any ideas what could be causing this?
I’m hesitant to take it to the dealer to diagnose; as they’re default answer will surely be that the HID kits are the problem.
Also, I have a Black Berry tune. I don’t think that could be part of the problem, but as integrated as the ECM is with everything in this truck, its worth mentioning.
sounds like a dash sensor problem to me.... might be faulty thinking its daytime
I don't think that's it because the low beams come on when it's dark out. Or at least I think they are...... I better check my tail lights to verify.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 600 Guests (See full list)
