No Sound From Radio
I have been having problems with my stock radio not having any sound. The radio would be on and tuned into a station, just no output from any speakers. Sometimes it would just start to work for a random amount of time. It fully has not worked for the last couple of weeks. I got tired of this and put in an aftermarket cd player. The player works fine in other vehicles. I used the harness adapter, so I did not have to cut any stock wires. The aftermarket player turns on, tunes into a station, but no audio at all. I am wondering if I have a factory amplifier in my 1998 K1500 SLT? If I do, can anyone point me to where it would be. I assume the factory amp may have gone bad, which is why I have no sound from both the stock and aftermarket head unit. Some wiring diagrams I look at show a factory amp.
Sounds like a short in one the speakers, the radio will go in protection mode and no sound.
would it go into protect mode for both the stock and aftermarket? I am just trying to figue out how to diagnose if it is the factory amp or not.
Mine did this until I found some chaffing speaker wires under the driver's side kick panel. The parking brake pedal was pinching them and causing them to short. Check there.
  • 3 weeks later...
you have to love your multimeter. Found out that the stock tweeter in the driver door was bad. I disconnected it and everything worked. Once I tracked that down based on the lack of resistance for that speaker wire, everything worked fine. Thanks for the help.
it was actually the 6.5" speaker in the door, not the tweeter. Once I got the speaker out, it was in such bad shape, the cone would not even move.
yep this just happened to my new stereo I installed. One of the speaker wires in the door was grounding out and the radio went into protect mode. Get in the truck and be as quiet as you can and turn the key. Listen very close and if this is the problem you will hear a faint static noise from the problem speaker. Then you can fix the problem. It is nothing major good luck and let us know which speaker it is.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
