alcohol
Kansas Kid
They only missed one slide....."Alcohol consumption can sometimes lead one to believe they can be a moderator"....
LOL! Is this how you got your job.......
Couldn't resist  ;)
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
