How-To: Fix GMT800 Jump Seat Center Console Stuck Latch.
charge74
Agree that these posts are very useful. Thanks for the detailed pics for sure!
I had/have a similar issue which I thought was caused by the safety roller after reading this thread but after getting it all apart I don't think that was the issue. I actually had a bear of a time getting it opened but when I did and then pulled it all apart I think the problem is a combination of the handle spring and the alignment of the angled piece that slides under the latching mechanism. And I'm not sure that lube would solve it completely as I'm pretty sure that the alignment is somehow off when it plunges in when you press on the handle. I really think that the alignment isn't right and that angled piece is sometimes hitting too high to not slide under the latch release and/or too low and getting hung up on the plastic bottom. Might also be that the spring isn't working correctly and it allows the handle to not travel straight back but who knows...
So my solution is to just leave the handle out. It seems easy enough to just reach a finger in and trigger the latch release. Eventually I'll probably make a longer tab to avoid having to fish around inside for it and at that time might also reinstall the handle but for now at least I'll never be locked out again! And I tested it out and the safety roller doesn't seem like it can fall out easily so hoping that stays put. If I end up fabricating a new handle I'll post some pics.
Happy holidays folks!
  • 1 month later...
Exactly what I needed. Everywhere else had my buying a part for a 2007+. I have a 2005 Silverado and this thread got me up and running in 5m with the pics. Took the dowel out, btw.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
