"change Engine Oil"
I do not have an owners manual, and do not have the steering wheel controls and my DIC is telling me to change engine oil. I just changed it not very long ago so how do I reset this?
... there is a way to rest the oil change indicator
.. I THINK this is the procedure... have not had to do it for a while....
.. turn key on , but do not start the vehicle
.. press the accelerator pedal three times fully to the floor ( not too fast.. and not too slowly)
you should hear a little chime noise and the light should go out.....
... repeat procedure if no response...
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
