Need Some Help
I think NNBS HD's have torsion bars unlike the 1/2 tons. If they didn't fit w/out adjustment, a torsion bar crank and/or torsion key replacement, they will fit. I was able to put 285's on my 2000 Tahoe w/ a TB crank. Check out gmfullsize.com. They've got a good amount of info over there.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
