Help!
gdn28
So i have the chance to get these wheels and I want to know if these will work with what i want to do. I have a 2009 gmc 2wd sierra wt and I want to put the rough country 2" level and nitto trail grabbers 32.8 inches wide I think...here are the specs on the wheel. will it work? thanks-
Size: 20" x 9"
Backside Spacing (in): 5.71 Offset: 18mm Load Rating:2200 Weight:43.44
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 254 Guests (See full list)
