2001 Silverado Wheel Offset
I am looking to put a set of factory wheels from a 2003 Silverado on my 2001. Is there any difference in wheel offset for these years? Thanks
No you should have no problem at all. If there is any difference it will be very very minimal.
Thanks, I just wanted to make sure before I bought them.
I had 2000 Z71 wheels on my 1995 Z71 and had no issues with tire swap, backspacing, lug pattern, ect. I dont see why these would be any different. May I ask what wheels?
Like these.
Wheel
Like these.
Wheel
As long as lug pattern is the same you will have no issues.
Like these.
Wheel
Cool
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
