My 09 Rusting Already
Well, I have 7500K on my truck and rust is already starting to appear on both front and back bumpers...going to take it to the dealer this week but wondering if anyone else is having the same problem
OMG! Where? I just got an 09 that I think was sitting on a lot in Oregon since last April. I'll go out and look tomorrow.
The front bumper right above the plate just below the middle of the grill and the back close to the centre
i have a 09 with 2700mi and when i got under it for the 1st time i couldnt believe the rust that was already under there. i also noticed little pin point spots in the door jams and hinge areas. getting everything coated this summer
Of course it helps that I don't drive it in the snow/salt/wintertime :D And that I constantly keep WD-40 sprayed on it!! :D
When I took it to the dealer for it's first check up they sprayed the hinges and door jams so I'm good there - haven't been under it since the snow started flying so I'm not sure what it looks like underneath
This is a pic of mine underneath with about 16k on it....
Nice...very nice. I'm new to the truck world so forgive me for asking but where do you spray WD-40?
Ya I drive mine through Buffalo winters so theres plenty of salt around this time of year. But I try to wash it once a week.
I guess it isnt too bad under there but more than there should for being considered brand new (it was a leftover). I guess the worst spot under there is the transfer case pan (if i remember right) and the exhaust flange had the most. But once spring gets here im gona hit the pan with a wire brush and give it a coat of black rustoleum. And then when i get it coated this summer they are taking care of the underside, wheel wells, door jams/hinges, and im not sure what else he said.
Just spray the hinge areas/all the moveable parts. Will keep everything moving smooth and that little bit of oil will keep the moisture and salt away.
Thanks, will do!
Pretty much everywhere under there!! (Rear-end housing,leaf-springs,shocks,spare tire hoist...anything thats painted!)
I'll spray it on,let it soak for awhile,then wipe off the excess.
I have done this with every truck I've had over the past 20 years,and every one of them always looked brand-new underneath,even with miles on them,The '99 I had,had 83,000 miles on it when I traded it in,and I had to drive it through 3 winters.....it still looked brand-new like the picture above.
I hate looking underneath a truck and seeing a Brown colored and rusty rear-end housing,leaf-springs,shackles,shocks,etc.
    • Pryme ! I was thinking of adding one to my 2024 6.6 gas  . Could you elaborate a bit more on your statement  Thank You
    • What a wonderful result! Great story telling to. You are quite multifaceted sir.  I'd keep it. Four is my limit too and yet we have five as well. One assigned the 'salt car' to do all those tasks you hate to ask of your 'Save for Good" crowd. 😉    Don't forget the antifreeze.    The Iron 4.3 is a favorite of mine.
    • Thanks Buck Wallace ! The more owners that tell me they are getting the same noise the more comfortable I will be with it !
    • Ancillary parts to the lower intake and connections went together without issue.   There was a brief pause when I leak-tested the fuel lines and injection system. Fuel was spraying all over. Lovely. O-rings weren't sealing the fuel lines to the spider, and inbound line was leaking at schrader valve, leaks at both flange nuts. It's moments like those when you just want to set fire to the whole shop, and be done with it. I was mostly enjoying the project up until that point, and was tracking to an agenda of having a running Blazer and a cold beverage in hand by dinnertime.    I found some larger Viton o-rings for my spider and some grease to get them to seat. One leak solved. Swapped fuel line Schrader core for old core. Still leaked. Swapped entire valve for old valve. Leak solved. Nudged the flange nuts a little tighter on the connections. Another leak solved. I could cycle the key / prime the pump and the intake was staying dry.    Reassembled the upper intake, with 10,000 vacuum lines, and filled the cooling system with water* (this is temporary, I'm not done with the cooling system yet).   Showtime!!   Cranked it over and smoke billowed, it was running rough. CEL illuminated and began flashing. P0300 and I somehow tripped a code for the TPS sensor, voltage low.    There's nothing as unrewarding as a vehicle that won't run (and produces the same code/problem) after hours of research and work.   Clearly I was in over my head. Was the timing off, did I stab the distributor incorrectly? Is the new distributor bad? With my limited OBD 1.5 data stream I really don't have a lot of parameters to see. The engine was pulling mad timing again (flooding?).   Think, Atlas, think.   1-6-5-4-3-2. One, six, five.....four, three, ....two. Wait a second. That makes no sense. 1 is the forward cylinder on the driver's side, so 2 should be the forward cylinder on the passenger side, not 6.    I can't believe it, but I'm looking right at it. Swapped 2 and 6 on the distributor and turned the key over, and...   It fired, coughed and stumbled, smoked, and then settled into a smooth idle. The scanner showed no codes, no lights on the dash, and the throttle was nice and responsive to gentle revs while it warmed up.   It's working!!! IT'S WORKING!!!   I paused for a late dinner, no cold beverage yet. I was determined to do my shakedown run. Did a basic safety and fluids check one more time and then went out and put almost 70 miles on it last night. She's a runner, runs good.   Came home and did a post-trip, post-mortem. The underside is dry *except* for where the last owner RTV'd the snow out of the intersection of the timing cover and oil pan. He said he had replaced the timing cover seal, but, my dude had clearly done it incorrectly and then tried to hold back fate with black RTV. Never works.   Yesterday morning I replaced the broken driver's door mirror. As much as I hate cheap Chinese parts, thank goodness for cheap Chinese parts. I think an entire new power mirror assembly cost me like $30, and it works perfectly. Replacement tail lights (faded, and one was busted) ran me about $12/side. I have a door pin kit ready to go in because the driver's door sags just a little and I want to fix that because there's nothing sadder than a saggy door.   I don't know what's next for this rig. Half of me wants to take some nice photos (there's a park nearby with a HUGE American Flag that always seems to be catching wind) and throw it up on CL/Marketplace for a couple grand and see if it flies. The other half of me... I've got a sweet running S10 Blazer that's been keeping my mind off of whatever I'm going through right now, and it's bringing some joy, and is cheaper than therapy. Maybe I'll keep it around for a little while. However, this is my 5th vehicle, just for me. 4 is really my limit, but they are not junk, so need very little attention. I don't know...there's a point where it's just too much and I don't see owning this truck long term. But I solved its major problem, got it running, so I'm going to stick a feather in my cap for now.   Sometimes we just need to get our hands dirty and fix something in the physical world to gain some satisfaction.
    • Happy 4th of July! Be safe out there tonight
