8.1 Swap
I have been throwing around the idea of swapping my 8.1 with a d-max. Is it possible? Any ideas on what it would cost? I have an 01 2500HD with a 6 speed manual behind it. The only thing I don't like about the 8.1 is the mileage I get. Other then that it is a great motor.
Thanks,
Russ
I have an 8.1 in my shed that im looking to put inan older 2500 4x4, and it is possible with some stand alone ecm/fuel managment, but as far as the diesel goes i think guys are gonna tell you to just buy a truck with a diesel in it. doesthe d-max even bolt up to a 4l80e or 6l80e, thought it wasjust duramax... although my 8.1 yukon has a 4l85e
Your better off buying a truck with the Dmax in it. There is a lot to do on a diesel conversion (fuel tank replacement, transmission replacement, ECM, exhaust system, , wiring harnesses, and find a solid donor motor).
...I have an 01 2500HD with a 6 speed manual behind it...
Since we're talkin' high dollar swap projects, I'd love to see what a six speed manual in my 8.1L Suburban would be like! Bye-bye center console.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,201 Guests (See full list)
