BAHAHAHA!!
pacodiablo
I used to live at 305 GAY street here in Auburn, along with another 24% of the student population.  I hated telling my friends where I lived.  Wasn't too bad I lived across from the free James Brown House.  Lot of parties there.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
