Code P0440
munsterlander
Hello. :shakehead:
I have a 1999 GMC Sierra SLE Ext Cab 4X4 with a 5.3L engine, 4spd auto, and apporx 106K miles. Put 10K miles on truck this year with no issues. Clean truck from southern Colorado and now 2 years in New York. Very little Rot/Rust which is impressive for Upstate New York.
Parked truck approx 1 month ago with no SES light or other issues at all, but when started approx 1 week later I was greeted immediately with the dreaded Service Engine Soon light. Scanned PCM with code reader and had P0440 EVAP code. Replaced gas cap (per AutoZone) but did not fix. Went through a tank of gas (many start up cycles) but SES light still on. Checked Purge solenoid and seems to work fine with 12V applied. In fact valve holds tight and wont let air pass through. Replaced vent solenoid as with 12V applied it would not engage. Removed charcoal canister and seems fine and will also hold air pressure without leaks. Checked all lines as best possible and see no cracks or leaks. Checked fuses and all OK. Fuel consumptions seems average for this time of year (cold) and I dont smell fumes near gas tank either. Note I removed positive from battery to reset computer after each change and/or test but still have issue. Ligh on solid immediately after start up and stays on.
Did not test with smoke/pressure tester as $$ is limited.
Please, any assistance is appreciated.
Thank You!
I had this same code after I flooded the crankcase with antifreeze. I took the tube off the top of the canister that runs to the solenoid as well as the rubber hose that leads to the side of the canister. I carefully blew some air through the canister. WHen I buttoned it back up, I was able to clear the code and so so far it has stayed off.
    HWN808
    HWN808
  • Who's Online   6 Members, 0 Anonymous, 970 Guests (See full list)
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
