275/55/20 Grapplers On 3" Body Lift?
i am about to have my shop order and install a 3" PA body lift for me. i currently have a 2" leveling kit on my 08 Sierra ext cab. i have 20" xd badlands with 18mm backspacing on 275/55/20 nitto terra grapplers.
i got the rims and tires when i got the leveling kit put on, they only have about 5000 miles on them. my question is, will they look out of place on a 3" body lift? i dont want to dish out more money for a bigger set of 33's until these at least wear out, or i can trade them.
let me know your opinions or if you have any pics of trucks on that size tires.
thanks a bunch
--i also posted this in suspension mods, but figured id get a ton more hits on here--
i ran 275/55/20s with just a 3" bl...no leveling kit though. it looked pretty good.
as a matter of fact i plan on going down to 275/60/20s when my 305/55s wear out (if they ever do....they're wearing better than expected)
they will look fine on a 3" body lift.. those tires are plenty big.. they are the same i have only i have the stock goodyear eagle ls2's.. that might look a little funny having 5" in the front with stock tires on the 20's but i think it would look fine until you get some 33's on it.
f&*( the haters dude.
Sweet. Will the body lift push the wheels in/out any? Stupid question but just curious....
No effect on tire positioning. I have the 275/60r20 with a level and 1.5 BL and think they look just a tad too small. I was wondering if anyone ever tried to fit the 275/65r20's (34's) on with what I have. That's what I would run if possible with your setup. See if you can find some info on it, I'd be curious as well to see if they'd fit.
Edit : Yes I believe the 32's would look too small with a level and 3" BL. Just sell the tires you have now, that's what I did. I only had 7k on my eagle LS2's and sold them to a neighbor for 400 cash, net spent was 500 for new tires mounted and balanced and an alignment.
The wider wheels and +18mm offset will help some... if they were on stock wheels i'd say they'd definitely look too small.
Don't get me wrong, i think it'll look like it deserves bigger tires, but i dont think it'll look horrible.
Here's how mine was with the 3" bl and 275/55/20s, my wheels were 8.5" wide but unfortunately they were +30mm offset
I will be calling the shop in the morning to have them get the lift for me. i will see if they dont have any tires they might want to trade me. they said it will take two days if they start monday, so i will have some pictures on wednesday.
krobocop: im actually moving to corpus christi in june. if i end up keeping these til then (most likely) ill be sure to let u know
shit dude that's awesome let me know. you get a job down there? i need a job in corpus i'm ready to get the hell out of here! i live in the middle nowhere west central texas.
:cheers:
yeah, im in the coast guard and that's my next duty station. im stoked about moving down there. im originally from houston so ill be back with family and friends again.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 481 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
