Pissed About 2009 Exhaust
i just bought an exhaust for my 09 silverado 4.8
dynomax kit # 39468
it looks right but the front pipe wont fit behind the cat!!
it says the kit is for 2007 too 2009 did they change it in 2009?
dynomax kit # 39468
Yup, they changed the connection on the exhaust in 09...I put on the magnaflow, they list the two different part numbers...07-08 and 09+
I looked on dynomax site, they only show the one you got for 07-09, which is wrong...I'd call them and give them a chance to make it right...back when I was shopping, I don't think they had one for 09+, but that was last fall...
ya i work at a auto-parts store and got a good deal on the kit $320. the rep talked the system up quite a bit. i thought for the price i cant go wrong.
guess what you can if it doesn't fit.
im guessing the pipe right after the connector right after the cat is a 3"
if so i will just buy a 3" stainless band clamp and cut off the flange on the kits intermediate pipe?? it should work right?
It probably won't seal properly. Why not take it to a muffler shop and have them expand the pipe to fit over the existing pipe. With their pipe expander it will be a 2 minute job.
Noticed that Gibson has modified their cat-backs with an included piece of 3" flared pipe that replaces the flanged end that fits the 2007/2008 cat flange. Maybe you could cut off your stock 3" pipe to length that would mate up with the Dynomax muffler, assumong it has a 3" inlet. Then you'd also have the benefit of the flex joint to absorb some of the vibration in the exhaust.
Does the 09 have larger pipe past the cat than 07-08? If so from like 2 1/2" to 3" or is it just some sort of expansion piece that is different on the cat or an odd size pipe all the way back? I never have looked at the pipe on my 09 but I always thought it was about 2 1/2" like my 2000 was.
well it was a 3" or 2 3/4" pipe. The connector on the exhaust after the cat on the 09 is a v style band clamp. The 07 and 08 have a 2 bolt flange after the cat. I got the pipe cut right after the V band clamp and put a normal band clamp on works good now
    needafix
    needafix
  • Who's Online   3 Members, 0 Anonymous, 403 Guests (See full list)
