Climate Control Problems
I have a 2003 Silverado with dual electronic climate control. When I first start the truck, the A/C blows out the correct vents. A few seconds later, the A/C switches to the defrost vents, no matter which vents are selected. The blower blows hot or cold at the correct temperature and at the correct speed, just always out the defrost vents. The problem started after I changed the battery. I have already tried to reset the computer by leaving the battery disconnected for 10--20 minutes. Just wondering if anyone else has had similar issues. Local mechanics want $800+ to tear the dash down and find the problem, not including the actual repair.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
