Finally Replaced The Old For Some New
Finally got around to replacing my front door speakers in my 2001 Yukon XL as it sounded like it was playing through paper bags. Decided to go with the Infinnity's due to all the good reviews. I ordered them through Crutchfield for $59 for the pair plus shipping. It also includes a wiring harness which made it cake to connect the speakers. Plan on about 2 beers per door panel. Very good sound, even with the stock radio, you can see fron the pic, these things were toast. Amazing in comparing the two how cheap the stock ones are, pure crap and that was the top of line stereo in 2001. lol - Oh well, all is good now.
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 623 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
