Tranny Chaterring
hey guys i have 2006 sierra 1500hd with the 6.0l and 4l60-e tranny and i can here some kind of chattering coming from the tranny, when in park the most. the truck as 64 000kms on it and tranny level is good. just wondering if someone would have a ideal Thanks
is it the trans or the motor?...only thing moving in the trans in park is the pump i think, you may just have valve chatter from the motor
I would check for the tightness of components attached to the trans, like dipstick tube or the inspection plate that covers the flywheel. Or heat shielding around your exhaust in the area of your trans.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
