Tranny Flush Question
Ok so I plan on flushing the tranny fluid and replacing the tranny filter this weekend, and I will be using the following link as my reference guide: http://www.gmfullsize.com/forum/showthread.php?t=179148
My question is:
In the thread it says to pump out and fill the tranny a total of 3 times, then it goes on to talk about how to replace the filter. But I am confused... Do I flush 3-4 times (leave it empty), replace the tranny filter, then fill??
Or.... do I pump out the old fluid once, take off the pan, replace the filter, then flush and fill 3 more times through the new filter?
I hope the above makes sense, thanking you in advance for your help.
John
My question is:
John
You pump it out through the new filter, the old filter will require you to drop the pan on a full trans and lose another 2-3 quarts of fluid. There's not going to be that much crap in your trans that it will ruin a new filter, and 90% of the crap will be in the pan anyway, which you clean before you re-install.
You are not pumping the entire trans out each cycle of the flush, just 3-4 quarts of fluid...there's approx 15 quarts in there.
My question is:
John
Every time I have done it I, either
pulled the plug on the pan and drained the fluid
or
pumped 3 quarts out using the line
Then changed the filter. (edit make sure you refill the pan before continuing) And continued on flushing the system till I used the 15 or 18 quarts depending on how many I had to flush with.
Just to make sure as MUCH of the fluid AS POSSIBLE runs threw the new filter..
Jbo
Thank you both. That is a very good how-to, and I have all the recommended stuff to do this, but the thread was not very clear on this area. Thx!
    BigJake
    BigJake
  • Who's Online   3 Members, 0 Anonymous, 613 Guests (See full list)
