Temperature Control Swap
GMGuy84
I was curious if it was easy or even doable to swap my standard(manual) temperature controls in my 2005 Silverado for the digital ones?
from what i have heard it's a real PITA, expensive, and not worth the trouble..need all components, BCM and reflash so i have been told..
good luck if you try..
yea that doesn't really sound worth it, especially since there isn't anything wrong with mine. i just like the other look
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
