Heater Core
I have a '99 c-2500 reg cab 5.7 auto, With AC. I smell some antifreeze when i open the glovebox or just stick my nose in the floor of the passanger side in general. I think the Heater Core may be leaking. If i determine it is the heater core, how hard is this to change. I read in my haynes manual that it involves disconnecting the steering column, moving the dash and gauage cluster up, etc. Just wondering if all of that was really necessary, or for those of you who have done this before, is there an eaiser way you were abel to get it out?
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
