2000 Silverado Lt With Factory Seperates Up Front?
Can both the mid and tweeter be replaced in the factory location? What sizes, adapters, and impedences do I need to make this work properly? Basically I don't know if there is a crossover feeding them, built into the headunit, etc. The entire audio system is stock and the pass side front door speaker is blown so I want to drop something decent into the stock location.
  • 1 month later...
Bump.
6.75" speaker is the measurement for a new speaker. most will buy a 6.5" and maybe put some Dynamat around it to get a nice air tight seal.
And yes, the factory speaker and tweeter can be replaced with aftermarket equipment in the original location.
Impedance's typically will usually be a 4 ohm.
The factory tweeter i believe has the cross over built onto it, so once you replace it with a new set, you're good to go.
Good luck.
    DNL going
    DNL going
  • Who's Online   1 Member, 0 Anonymous, 410 Guests (See full list)
