6 Lug 14 Bolt Rear
This is a hard to find 6 lug 3/4 ton rear end with 3.73 gears and a G80 locker. It is equipped with disk brakes including rotors, calipers, and pads. The spring perches have been moved to fit on 80s models half ton trucks but they can be moved again to fit your Z71. These are great axles for those who want to stay 6 lug and they can handle lots of power and tire.
I bought it to put on my K5 but never did. The rotors are rusty from sitting under the barn for a couple years.
The axle is in Dallas at my Dad's. I am a little north of Lake Charles in Louisiana. I am going up to Dallas this weekend and next weekend and I can take pics or haul the thing back down if someone wants it. I will deliver between Lake Charles and Dallas metroplex for free or within a couple hours of my house for a fee. I'm not going to ship it though. Asking $350 cash.
I have a set of 4.56 gears for sale too.
Basically I want to know if they'll fit under a 2007 new body style...I checked one once and it was too narrow...
The 2wd and 4wd versions were different widths. I want to say this is the wider one. I'll see if I can get my uncle to measure it today and I'll get back to you.
According to my uncle, it is ~66.5".
I have some new bearing and seals that will go with the axle. I bought them to rebuild a different rear end (this is the 2nd one I have had).
Is that from outside to outside of the brakes? I just measured mine and it was close to that...gonna see where a buddy of mine is in LA.
  • 3 weeks later...
He said from outside rotor to outside rotor it is 65 and 3/8". Then 1.25" to the hub so it should be be right at 68" wide. My math was off. :(:D
I also have new spring perches from Ruff Stuff and HD u-bolt plates from DIY4x that can be added for extra $$. They ARE NOT for sale separately.
I'm also looking for ATV parts such as a NEW Warn winch at least the 2500lb size, or some 28"+ Zillas for a 14" rim.
  • 1 month later...
Damn!!! All the good stuff is so far away. I am having a lot of trouble locating one locally.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
