Alternator Squeaking Sounds Internal
wolverine_22
Ok..i thought it was Idler pulley replaced it, it was making some of the noise but with the belt off...i spun the alternator pulley and theres a squeak...sounds like its coming from inside alternator???...
this mean alternator bout to go out?....or just an annoying noise...no problems :dunno:
  • 3 weeks later...
you can try using an auto stethoscope, screwdriver or a hose and hold it to your ear and different parts of the altenator and make sure where the noise is coming from. chances are its a bearing. You can rebuild it, sometimes there are kits available or you may be able to find another bearing at an auto/farm store. Many times u can take the sealed bearings, pry the seals off, clean and regrease them which I do with many bearings, although the metal seals may crack, I find the rubber ones easier to re an re.
Yup +1 on the Bearings.
Sometimes a squirt or two of 3 in 1 oil makes it go away for a bit...if you can get it on the bearing.
I would get ready for a new alternator or a rebuild though...if I were you.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
