I just bought this truck yesterday:
I didn't notice this problem during the test drive/inspection. I drove it back home about 2 1/2 hours from the dealer I bought it from, running the a/c the entire time (which worked perfectly fine), and today I noticed a small amount of oily water (definitely not coolant) on the passenger front mat:
Which appears to be coming from up above:
My day job is running a GM Certified Collision Center, and I have access to GM SI, and I was able to pull this diagram:
I had read from others that its common for the drain to clog and the water then fills up the drain tube and overflows into the cabin. I pulled the driver's fender liner back and was able to snake a small plastic bristle brush up the drain about 4-5". Nothing came out and the the brush was bone dry. I'm not sure if I still have warranty coverage as I'm right at the 3 year mark. I could not find any definitive answers via search as to what is the source of this problem.
Is it just me or does it look like they raised the height of the back window; eliminating the minor fastback look to the cab? That fast back look was great... until you added a shell that couldn't follow the roofline very well.
I wanted a fleet of green trucks for my business but green is fleeting in the order books. (Although every other manufacturer has beautiful greens right now)
I started building out a fleet of Navy Blue work trucks thinking blue is a safe color that will always be around. GM then goes and eliminates Blue for everything except Denali and above. Why does GM hate color so much? Grey, grey, black, white, two reds and brown.
WHERE'S THE GREEN?!?!?
