Can't Get Into 4-low
I'm having trouble getting my 2005 Silverado into 4 Low. I have push button 4wheel drive and have no problems getting into auto or 4 high. When I push 4-Low the light just flashes and it stays in 2 wheel. Any thoughts?
You need to make sure your truck is in neutral before putting it into 4 low.
was the transmission in neutral when you tried to put it in 4wd ?
mine does almost the same thing if the trans is not in neutral - flashes and stays in 4hi
Yeah, what these guys said above. Stop, put it in neutral, then put the truck in 2 low, and you will hear a clunk and maybe a shudder as it locks it in, and then don't rev the truck very high either...slow speeds only.
Shouldn't ever really need 4 low unless really pulling short distances with a heavy load. I know when i bought my truck though i made sure it went into 4 low though, so can understand you wanting to try it out.
I have noticed sometimes depending on the terrain I have to put the brake down or hold the brake pedal....... Also, Place in park or neutral with the shifter...... If that does not work... Kill the truck and try it.......
Jbo
From the Book
To shift to the Four-Wheel-Drive Low position, the
ignition must be in RUN and the vehicle must be
stopped or moving less than 3 mph (5 km/h) with the
transmission in NEUTRAL (N). The preferred method
for shifting into Four-Wheel-Drive Low is to have
your vehicle moving 1 to 2 mph (1.6 to 3.2 km/h).
Push the Four-Wheel-Drive Low button.
You must wait for the Four-Wheel-Drive Low indicator
light to stop flashing and remain on before shifting
your transmission in gear.
Notice: Shifting the transmission into gear before
the requested mode indicator light has stopped
flashing could damage the transfer case. To help
avoid damaging your vehicle, always wait for the
mode indicator lights to stop flashing before shifting
the transmission into gear.
It is typical for your vehicle to exhibit significant
engagement noise and bump when shifting between
Four-Wheel-Drive Low and Four-Wheel-Drive High
ranges or from NEUTRAL with the engine running.
    Selfman
    Selfman
  • Who's Online   6 Members, 0 Anonymous, 620 Guests (See full list)
