How many Michiganders do we have here?
TheScaryGuy
  • Replies 118
  • 4 weeks later...
I'm from Gladstone, Michigan which is in the South Central U.P. Although I am currently attending NMU so I am living in Marquette! 100% Yooper
  • 2 months later...
  • 4 weeks later...
  • 3 weeks later...
  • 4 months later...
Used to be in Waterford as a youngin', moved to Arizona for 20 years, came back to Battle Creek for 4 years, moved back to Arizona.
