Ride Control And Bilstein Install
After my 7 month vacation in Afghanistan I have finally got the chance to get eveything installed that has been sitting in the garage. The Bilstein adjustable shocks are the best modification yet and the Ride control bags have really helped keep the truck more controlled. Here are some pictures. Sorry about the dirty underside, Carolina forest is not the best place for pretty belly shots.
Gauge location
Bag bracket (still room for the future tires (285)
Bag/Shock/block
Manual air valves
Compressor under the back seat
I have the same airbag setup and love it! I have my compressor mounted under the hood and its pretty loud, isn't it kind of annoying to have it inside the cab?
No not really, under the seat you dont hear it much. Also it only comes on when either under 10 PSI (auto switch), or if I need to air up or adjust. Plus it keeps it out of the weather.
Next question, The 3500 I'm driving is a Duramax. It already has an air pump on it. Can this air pump be used to operate the airbag??
I suppose you could run a inflation line from your current pump with some creative modifications then just use the manual fill valves in the back of the truck.
Nice install. Is that a custom bumper?
Thanks, It is a Fab Fours bumper, Courteous of the NC state tropper that rear ended me about 10 months ago.
When I have time I think I may put in a quick connect some where and a shutoff valve to the bags. That way it can be used as a compressor for a low or flat tire as well.
I just installed my AirLift air bags a few weeks back. How do you set it so it auto fills the bags to 10psi? Do you just mount the sensor lower on the frame?
I have an adjustable sensor in line by the compressor (5-10 PSI range). I do not see it on their website but it came with the compressor. Might want to call them, should be cheap.
    tblt44
    tblt44
  • Who's Online   5 Members, 0 Anonymous, 782 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
