Advise On Airbag Asst.
I do a lot of hauling in my 3500 crew cab long box. Mostly hardwood lumber. I really get tired of jacking around with the headligts. When I put a load on it lowers the rear and of course points the H/L at the moon. My thought is to put an air bag asst. on the rear to help raise bed to mantain the position of ht H/L. Any thoughts or recomendations? Leroy
Damn Leroy how much wood you hauling with that thing. You could do a 5th wheel setup if its a ton of weight, but putting the airbags on is a fairly simple and cost effective fix.
I have a pair of Air Lift assistance bags on my 1500 and I love them. Don't have to worry about the head light issue any longer, it handles better and is safer.
http://www.airliftcompany.com/index.php
Very easy to install
I have been looking at this similar kit and was wondering what is in that gap from the factory? I havne't looked under my truck yet.
Here is a before pic
Well now that you ask, I do pull a 5th wheel or gooseneck most of the time. However on occasion I need only to take a smaller amount of about 500-750 board ft. Wt from 3.28 - 3.89 lbs/bf. so do the math. I'm telling ya this 04 chev 3500 is a work horse. Only thing I'm unhappy with the General about is the wireing. It really could have been done much more gooder. :sigh:
Thanks for the response. I'm going to look into this kit.
So when aired down the bags do nothing then add air and it firms up the rear to keep it level? Looks that way. Sorry hard to picture it.
You got it.
These work great. http://www.supersprings.com/ I added these to my 05 1500 when I was pulling my 30 ft bumper-pull trailer. They can be installed in less than an hour and you do not need to disassemble anything. They come with all of the hardware and mount over your existing springs. They do not change the ride until additional weight is added, so the truck will ride the same with no load. Much less money than bags and worked perfectly. Best thing is I sold them for almost what I paid when I sold my truck because they were so easy to take back off!
How is the ride when they are aired up? Also any pics of the location where you air them up? And how was the installation?
Very easy to install. By my self it took about 2 hours. I ran the air lines down the frame to the bumper and the valves are mounted in the bottom plastic (no holes drilled in the metal). I don't have a pic, but I could easily take one if you would like to see it. In fact if I get a chance here before I leave work, I will.
I have not ordered it yet, but I found a kit for an on-board air pump that you can air up and deflate the bags in the cab for $140.
This shows a bit of the various locations of items in the kit. Very easy day installing and even easier operating.
http://www.gm-trucks.com/forums/index.php?showtopic=113572
The above link will show you the pump from airlift and the location for the rear air valves if you dont want to drill holes. (license plate bolts).
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
