Tire Size & Computer
Greetings to this forum! I am a long time GM truck owner. First new one was a 75 crew cab. Then a Dually CC on 1980. Even had the first Duramax CC Dually in our province. I just bought an 09 LTZ ext. cab. I had the dealer change the rims from 20 " to 18 ". He claims they reset the tire size in the computer. Here are my questions: Do most tire shops have the ability to reset tire sizes? Will my Scan code reader show this info? BTW: I pickup the truck this weekend and Am very excited. Have been driving a Taco for the last 5 years and I need more room. I was suitably impressed with the power of the 5.3. I just wished they had the 6 speed in 09.
Bruce
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
